Hi guys i’am trying to create a top-right corner dropdown menu but i can’t use a rectangle or anything else since my header is a floating group for some reasons. I was thinking about a popup but without any background blur so it shows like a regular dropdown menu but when i use the element popup it automatically positions itself in the center of the screen i want it to be on the right corner on a custom location is it possible i think it is right?
Could you put the “top-right corner dropdown menu” into the head floating group?
Do you have a diagram of what you’re trying to achieve or screenshots? That would help.
Thanks
Here is some info. There are a few more workflow count topics on the forum.
