Need Help (Stripe Integration on Bubble App)
Please, I need help with integrating Stripe on my app, to work seamlessly. I am not sure what I am doing wrong. I will really appreciate any help I can get.
Thanks
Hey @everythinghr :waving_hand:
You are working in an old version. Go to the plugin settings and upgrade the version (checkout v3) of the plugin. :blush: That’s the first thing i would suggest.
I would recommended you use the api connector directly
by the way, is it a subscription or marketplace transaction you want to implement?
. Thanks for your response. Please, I am not sure I understand this. I want to implement a subscription. I installed Stripe plugin or maybe I installed a wrong one? the screenshot is what i installed.
Thanks for your response. I could not upgrade as I could not see where to upgrade it. This is what I installed
You can update it in the Stripe plugin settings here
Oh! I just saw it from your screenshot. Mine was on checkout v2. Let me upgrade and see if it works. I will let you know.
Thank you so much!
Thank you very much! It’s working now after the upgrade. Grateful! :star_struck:
Awesome. good job :clap: Glad you figured it out. :blush:
