I NEED HELP WITH THE WORKFLOW STEPS TO SAVE DATA IN THE TEXT BOXES THE TOUTORIAL VIDEO ONLY SHOWS IT FOR A MAP SEARCH I NEED IT FOR SAVING THE INFO FOR EACH LINE ANY HELP IS APPERICIATED
Were it says ‘click here to add action’ you need to click this select ‘data’ and then create a new thing. You then need to select the type which will the table in your database. Then you need to ‘select another field’. You then say what ever it is called in your database = the name of the input you want to save it to. If you try the lessons on bubble (https://bubble.io/lessons) saving data. It should show you there.
It looks like on the screenshot you are trying to add a new user. If this is the case you will need to use 'sign the user up rather than ‘create new thing’.
