Need small help with autoplay of a video
Hi
I have a popup with a video
I want that this video will autoplay on any device
I am using Vimeo embedded code - with autoplay - and it works great on my desktop, but on tablets, the popup is loading but the user needs to click play in order to see the video.
Do you have any other way to fix it?
I am using Vimeo but i can use any other hosting, also - if any plugin is required i will purchase
Thank you!
