[π—£π—Ÿπ—¨π—šπ—œπ—‘] Path Hopper: Better SEO, Better URLs, Better Bubble
Useful Links
DEMO
PLUGIN PAGE
DISCORD
MORE PLUGINS
What is it?
Path Hopper is for advanced slug/path functionality. You will be able to use this like you could use β€œGo to page” but instead it will allow you to update and read paths and parameters without reload, and can also update and remove parameters dynamically.
Why did we make this?
We needed something that actually worked for our use-case and was a more improved version of our Path Hopper V1 tool in our Toolkit plugin. This allows us to turn an infinity amount of paths into dynamic paths, which allows us to bring our total β€œpages” down to a minimum. This is also very good for SEO.
JUST ADDED :
  • Now automatically grabs the keys and values from the url.
  • Separate action to modify parameters.
  • Parameters are completely dynamic KEY & VALUE .
Features :
  • PathHopper works on any page so you can change anything based on the element states.
  • Better SEO results.
  • No more parameter clutter.
  • No refresh on update.
  • You can reload the page and it will still work.
  • Simple to use.
  • Easily update & read your parameters.
Events :
  • Path updated
States :
  • Path list (list of texts) - the path list of the current page.
  • Path one (text) - the first path of your page.
  • Path two (text) - the second path of your page.
  • Parameters (list of texts) - the parameters within your URL.
  • Keys (list of texts) - The read keys from your parameters list.
Actions :
:globe_showing_europe_africa: Update Path : Updates your path.
:globe_showing_europe_africa: Set Parameters : Add/Remove/Update parameters
:globe_showing_europe_africa: Go forward : Goes forward within the browsers history.
:globe_showing_europe_africa: Go back : Goes backward within the browsers history.
:globe_showing_europe_africa: Thanos : Resets your params and paths to starting path.
SUPPORT
If there are any issues or suggestions you require, please contact us through our support channel, through Discord, or through here. Please review this demo and documentation before submitting a report.
Created by @GH5T.
Hello friends! Today I have worked on the documentation for this plugin.
Link :arrow_right: Documentation
This document teaches you how to use Path Hopper efficiently and transform your application into a fast and responsive machine.
