Hello la team,
Je souhaite filtrer un repeating group avec les données d’un autre.
Vous savez comment faire?
Hello la team,
Je ne peux pas repondre en francais mais…
You can put a repeating group inside another repeating group in order to link the data that is displayed. The data may be linked by your data model or by filtering eg:
Hope that helps!
It worked. It was not really what I wanted to do, but I like that way too . I just added a toggle workflow on inner repeating group and now it’s more readable.
So thank you so much @tony.macp.
