I’m having a hard time trying to make the pop to be scrollable.
I have several fields on the popup that are corretly stacking up when width shrinks. The issue is that when it’s height gets bigger then screens height it’s not possible to scroll down making some of the fields inaccessible.
I have the exact same problem, i’ll let you know if I find a way
Hey @benoit.devilliers and @ppbrasil ![]()
This is a bug. Please report it so it can get fixed. I’m waiting on this fix too. ![]()
Thanks @J805 I reported it !
Maybe it would have a better chance to be fixed if we entered the same informations in the report ? what do you think ?
I’ve just copied and paste the same info here in the post. But really don’t know whats the heuristic they follow. Wont cost to try.
Yeah, they seemed to push a fix but it doesn’t fix everything yet. They are trying though. Hopefully it doesn’t get pushed to the end of the line again. I hope we don’t have to wait another 2 weeks to finish the fix. @bubble
