Issues with Responsiveness and Scrolling in popups
I am building a popup data collection widget.
the widget is taller than the RE that it belongs to . it will be taller than the page it lives on at times.
I am unable to make this Popup scroll and am having issues with the responsiveness when the popup is set to column
This is the new responsive engine I believe. At this moment in time I would suggest submitting a Bug Report. Best thing that could happen is it helps the Bubble team put through a fix…worst that could happen is support explains the behavior.
It sounds like a bug to me though.
ended up using a workaround but it produced another strange but less annoying bug
