Preparing database and datasources for survey data and charts
Hello!
I’m new to bubble and heavily fighting with database and data sources.
What I’m going to do is to create a reporting of survey data. The data should come from perspective, a great funnel builder. They will be inserted into the database by webhooks. This is not part of my current issue.
The big question is: Can I, and how, solve reporting and charts the way I plan it?
My goal, an example of it:
The data in SQL would look like that:
My current configuration in bubble looks something like that:
Yes, the data that comes from “perspective.co” is not normalized, so I have repeating text within the database that I need to filter/group out.
So while I can create entries in bubbles database, I cannot request them the way I want.
  1. Survey Answers (“Survey Values” called in the bubble db) should be grouped, because I don’t want to have the same answer shown repeatingly.
    I do create a repeating group with survey questions, then I create a repeating group with the answers:
  2. Showing the value works fine:
  3. Also showing the amount of answers I got worked fine:
But while I grouped the survey values, I cannot get the amount of survey answers that matches current survey answer, because by grouping, they got put together (or I don’t know how to model the query):
The output looks like this:
So my issues are:
A. How can I calculate the percentage of the answers, while they got grouped?
B. How can I have background rectangles sized by data?
Also did I tried to use charts, like in my example but failed hilarious:
The value expression seems to make no sense in my case, while I basically need to count each element and then deliver it as an array for values, but after the red marked text i cannot add “:count” or something.
Is there any hope?
Thanks for your help!
Best
Patrick
