Problem loading iFrame
Hi there.
Im having problem to load content into this iframe
I created the HTML element and inserted the code above, but nothing happens.
The url alone works fine.
Any problem with the tool,permission setting in my app ?
Cheers ?
I’ve noticed some strange things with iframe. Instead of using the checkbox in Bubble for “use as iframe” have you tried unchecking that box and just enclosing your html in <iframe> tags? Another user, somewhere in the forums, had posted a web app that helps you generate the appropriate tags and properties:
If that doesn’t work, you may want to take a look at the javascript running in the child (i.e. iframe). It may require libraries that are not yet compatible with Bubble.
not working :frowning:
Can you post a link to the editor?
@supernaturally thanks a lot dude, but I already delete it and give up to use that terrible tool.
