Before I submit a ticket to support I would just like to get some info from the community:
Is anyone else having problems saving and seeing style changes?
I don’t seem to have a problem on my macbook air, but I do see the issue on windows.
If you think it’s a bug the best way is to file a bug report (bubble.is/bug_report)
definitely will. just thought I would gather more info for you guys first.
I actually have a similar issue on Windows, I can reproduce pretty regularly but I can also fix it immediately. Any time I apply a new style to text, it says “saving” for a long time, until the “saving” text turns red. Nothing ends up working for a bit, so I end up refreshing to see that the style (and anything done after the style) didn’t take. A few more tries and it works.
@vega.andrew if you want to file the bug report, that’s great. I’ll let you do it
