Problems With Bubble Today? (5-28-25)
It seems as though Bubble is experiencing problems right now?
Workflows are not working right and can’t be created?
Something is not working right…I do know that.
I think I have problems on my end as well. Some pages are not loading properly on my app.
Yes, complete standstill…
freezing all the time
Yes, my Editor is constantly freezing… :pensive_face: I have restarted my computer many times with no improvements
I will submit a bug report.
Not sure what happened.
My app has been working great and then today I got a call that some of the pages were jumping around and not usable.
Apparantly, not sure how, some of the workflows were changed and when I went back in to correct them I couldn’t modify them.
same - my editor workflows don’t refresh when changing or editing.
slow, freeze, missing worfklows… it’s worst day after day …
I had 3 different workflows that had parts of them disappear.
When I went back to add the missing parts, I couldn’t change anything on the workflow.
I now seem to have it working even though a couple of the workflows aren’t showing what is actually happening on the workflow.
Interesting problem.
Lots of issues for me today as well. I had to close my laptop and take the afternoon off because it was impossible to work correctly
The editor is completely unusable for me and crashing constantly now.
Still having the same issue as some page on my app is not loading properly. I noticed that the Externally Measured Latency on bubble status is getting high.
Glad it isn’t just me. I spent hours this afternoon trying to troubleshoot user complaints about issues that appeared out of the blue. Applied workflow fixes that should have worked, and didn’t. All of a sudden, those same fixes are working now. Very odd.
Noticing all sorts of funky stuff in the editor. Actions not appearing, workflows stuck ‘loading’
Yep, workflows are not appearing on the editor, folders aren’t renaming..
Something is definitely going on. Can someone from bubble confirm this
@fede.bubble
Same here.
Workflows won’t show up.
I can do a workflow, but it doesn’t show…
but it still executes, so I’m not sure how they will work once they resolve the issue.
Still not working something. What are you doing guys? 5 hours without reply of staff.
Same issue, no one’s replying for my concern. It’s been 4 hours for me.
@fede.bubble can you please help?
you should all make bug reports if you haven’t already @ Contact | Bubble
