Repeating group and problem with pop up
Hello everyone!
The case is simple. I have a repeating group of clients (with search of current user’s company name) with those names and I need to make pop up for updating info.
So, when I’m trying to display info using pop up I cannot select data to display.
What do you think about that?
Is the change_current_client A element datatype the same as the repeating group current cell’s datatype?
Also you should clean those 22 issues I will be easier to find where the problems come from.
Thank you so much! It’s a solution!
