Running results system
I have been dabbling with php and MySQL building a sports results system. I wondered if it was possible to easily build something like that using bubble and MySQL.
Thank you.
What does this system do beyond outputting tables of results from sporting events? Bubble can certainly output data just as you would with PHP and MySQL, but until seeing screenshots and description of current PHP functions it’s tough to give a solid answer to your question.
There is a plugin call SQL Database Connector that you might want to check out: Introduction - Bubble Docs
