This is a very dumb question but I know I must be missing something, I have a search box that looks for entries name however the autofill does not automatically stay instead it clears and I have to type it again in order for the autofill to work I will post a gif of it in action to explain shortly figured I might as well look for an answer here before redoing the entire searchbox.
I saw this issue too. Check that you are not using the searchbox value in the group that its inside. If you put the searchbox value as the group’s data source it results in this issue. Removing it cleared up the issue for me.
