Tab Element does not appear in On Page Load - Set State - Element
I am having difficulty getting the Tab element in ‘Element Template’ working correctly.
Although the tabs work as expected, I immediately get an error that the page on load workflow is incorrect.
I try to add the element for the group tab to set state as 1 on page load, the element doesn’t appear in the element selection.
I can however change element states when buttons are clicked.
This effectively means although my tabs work, when the page loads none of the tabs are selected by default.
The only other thing to add is that the tabbed elements are within a repeating group.
