Hello Bubble team and world. I am currently on the $16 personal plan with a live application using bubble as a backend for a drop source mobile ios front end… The bubble side seems to run a bit slow. I am currently on the Individual Personal Plan and I am considering upgrading to the team professional plan to get better and more consistent speeds. Is there a way to test the speed difference before? If not is it easy to switch between the two? Can I upgrade for a month, then if I do not see any significant difference in my application revert back to the lower plan easily?
There’s a chance that it will help, depending on how you have place things. Free to try for one hour (2 units). Easy to revert back from one plan to another.
Thanks @JohnMark I tested it and it does not seem much faster. May be a bit more consistent but seems like the same speed. I guess I will upgrade once I have the users.
I’ve found that it isn’t until I’m on the Professional plan with 8-10 extra units that I really notice a considerable difference in app speed. So once you’re paying about $250 per month Bubble is fairly quick.
At 40 extra units it’s amazingly quick.
Thanks Keith super helpful… I wondered if I could get more outta a larger budget
