Hello community,
I’m trying to add songs to an app, for this workflow it is a sound when someone buys something with stripe. But I don’t get any sounds and can not figure out why …
Here are the worflows, design, and errors I get :
thanks a lot for the help !
Make sure your sound file has ‘https:’ attached to the front of it. Bubble’s file uploader by default does not have that text.
Make sure the element is visible before running the action.
Thanks ! I used the Circle music player and used the option autoplay when a new song is set, works perfectly.
