I’m using Google Geocoding free plugin for my first build. Somehow It doesn’t seem to work with the searchbox element. If I use the standard Input element, I’m able to use the “value” of the Input and save it to the database using workflow. But for some reason if I use the Searhbox I’m not able to do the same when I look for “Searchbox A’s value.” I’ve tried using extraction as well. Thank you!
