I’ve encountered some strange behaviour that looks like a bug to me.
I’m adding a filter to my datasource, and I wanted to create multiple constraints. As you can see in this video, the first contraint goes in without issue. When I try to add another constraint, I am unable to click on the + to add a dynamic value, but I’m also unable to delete text if I type it in. It appears that the constraint blocks the system at that point.
I was testing things, hence all the filters, however… I still have 3:
1- Server side filter tied to a search box for selecting the Account
2- Client side (advanced filter) tied to checkboxes for roles
3- Client side (advanced filter) tied to input field to search for name, surname, email, id.
While 2 and 3 could be merged, it is a pain to edit expressions that change during development, even with the new editor.
Does merging 2 and 3 actually make a difference in performance?
Also, the constraints if I understand, are additive. In a text search I want to return any record that contains the text in any of the fields. Hence I concat them on the client and then use contains. If I put multiple server side “contains” they would be treated as all of them being needed (no way to say “or”). Am I missing something?
Thank you very much for your help today. I combined all but one of the filters into a server side, with the sort, and it works well. I created a backend workflow to make a search field, and contains works very well.
