Workflow issue when using dropdown
Guys I have 2 options in my dropdowns linked to my register/sign up media:
Home Improver
Tradesman
But when I run preview and select Tradesman it keeps running the 1st workflow which is Home Improver…
…Also…not the brightest…
Please help
Given that you haven’t yet shared any information about what you are currently doing, it’s going to be pretty difficult for anyone to be able to offer any real help here… other than complete guesses… (it could be any number of things you’re doing wrong, but my first guess would be your workflow conditions are wrong)…
So feel free to share some more specific information about what you’re currently doing - screenshots or a read-only editor link will make it much easier for someone to diagnose and give suggestions…
Otherwise, all I can suggest is check in the debugger to see for yourself what’s going wrong, and double check all your workflows, database setup, actual database entries, and privacy rules…
Here are some screenshots
Screenshot 2022-09-15 154722
There’s a lot here that doesn’t seem to make a lot of sense… (unless I’m missing something)…
You’re first workflow is set to run anytime the input value changes and the current user’s client option is Home improver…
So, presumably the current User’s client option is Home Improver, and that’s why the workflow is running… in which case that’s the expected behaviour here…
I’m not entirely sure I understand what you’re trying to do, or what you’re expecting to happen here…
I also don’t understand why you’re running a ‘sign the user up action’ when the input value is changed (and I don’t know what your second workflow is supposed to do either, as you haven’t shared any screenshot of it.)
But in any case, without seeing your app in more detail, or knowing exactly what you’re expecting to happen, it’s difficult to help…
But if things are working as expected then use the debugger to help identify the issue.
indent preformatted text by 4 spaces
Thanks for the help. Basically I want to create a App where Tradesmen subscribe to Clickatradesman and I have created the following Data types:
What I am looking for is sort of: If then…go to… at the moment it only selects home improver as I assume work flows run logically
