For some reason workflows with conditionals only run sporadically using the Ionic toggle in a web app (non native app) environment.
Anyone else had this? So i’ll click the toggle and the workflow will run. Then I might toggle it again and no workflow runs, then if I refresh the page its all good again for one or two toggles, then it stops. Doesn’t update in the DB either
Can you share a link to the app editor?
