158 Issues where there were no issues yesterday
HI
Today I opened my project that was running live with no identified “issues” until yesterday. And here is today’s situation:
What is going on?
I dicovered that workflows of other elements are now visible in index page workflows where they obviously do not work.
Aleš
I had once a case like that, when somehow my API call got outdated without me even touching it. And later I couldn’t recall it due to some issues. But I would guess it may be related to some api call if you are sure - you have not deleted any field in the db, deleted option set etc.
Check one and do the investigation - what is particaullary going on.
Maybe a plugin died?
if you’ve just run “cleanup app” then that creates a lot of issues in the checker because things are confirmed as deleted and so then most (not all) arguments that reference those things error - whereas when you just soft delete them in the backend they still exist and are just “hidden”
although “cleanup app” doesn’t delete them either - it just hides them from the editor
I checked plugins and all seems to be ok - no info about update or removal. I do not use them much. Especially not on the index page.
Can it be related to Page HTML header? I added some code the other day for facebook. It was all ok for at least few days…
I did not cleanup or optimize app recently.
Hard to say. I haven’t used HTML headers that much. But in general - if you check errors one by one, don’t you see some patter like a value x is missing? Maybe you cna switch to live version and compare this error to what is on live - what value is missing, what has changed etc. Then you will grasp the logic what might have happened.
Realy hard to say. I checked few and “Reveal element” doesn’t show element that suppose to be in error.
It looks like invented elements or they changed sometihng and I got old deleted elements back in app…
So now I should manualy go through 158 elements and delete one by one… ?
See above - I discovered that workflows from other elements are now within index page workflows and they obviously don’t work. I did not put them there. It seems to be some system works not performed correctly!
Have you tried rolling the project back to an earlier state? Any changes?
Hi everyone,
Same situation on my end. I had around 30 errors suddenly appear this morning, while everything was working fine yesterday. I’ve already fixed most of them, and still have 11 left to tackle.
I’m posting here as the context of my issue seems very similar to what @atrium.celje described. Of course, if it turns out to be unrelated, I’ll move it to a separate thread.
What’s odd is that many of the errors are related to missing event names — which seems strange, since I’m quite sure I must have defined them if they were required. I wouldn’t have been able to deploy to production otherwise:
Also, as shown below, Bubble now throws an error where it expects a PatientReviewsCampaign thing, even though that’s exactly what was previously provided (PatientReviewsCampaign now). That reference has inexplicably become invalid. It’s easy enough to fix, but it’s concerning to see errors appear like this without any change from my side:
Has anyone else experienced something similar or found an explanation? Could this be linked to some internal system update or a backend glitch?
Thanks in advance!
Georges
We apparently have a problem, after the merge it completely doesn’t see the reusable elements
I noticed this when I toggled the new workflow editor on and off - it caused errors in the workflows I built in the new editor when I rolled back to the old editor - not sure if it is still the case
I also used new view of workflows. I now changed back to old one but the errors remain.
What I noticed is that I have (among others) in my index page workflows also other elements like from reusable elements.
Have you tried rollback? Does it help?
That’s a good observation.
I’m asking the team to investigate what’s going on here. Thanks everyone for reporting.
Have you all submitted a bug report about this?
It is ob bugs list.
I just noticed that I can not switch back to old way of viewing workflows. Is that intentional?
I find old vesrion’s way of deleting unusable workflows easier / quicker..
Aleš
Yeah the team rolled out the new WF tab to everyone today permanently.
Ok, Thank you.
V sre., 23. apr. 2025, 22:01 je oseba Fede via Bubble Forum <notifications@forum.bubble.io> napisala:
That roll out is likely the cause of the bugs. I am experiencing it now too today.
Please ask team to fix this with urgency. I’m unable to work with this bug as it affects so many areas with data…it would just be a game of whack a mole if I were to try and resolve all on my own.
Can you guys confirm if this is happening outside of reusable elements? Would help them narrow it down.
I made a rollback to get clean situation. Hard to say since I copied some pages in that caused issues.
