Can anyone recommend a font within Bubble that is the closest alternative to Times New Roman?
If you use the search function on the font types, most of the fonts that have “Serif” in the name, it’s a good place to start (ex. Droid Serif, IBM Serif, Source Serif). If there are multiple weights (ex. 200, 700), typically best to select the one that says “Regular” or 500.
Thank you Dan!
