Group not stacking rather going under floating group. Help?
Does anyone know how to make it so that the group doesn’t go under the header floating group, rather stack under it? Currently, I can’t access an option at the top of the blue group because it’s under the floating group. Any ideas why this happens? Do I just have to always make the top margins in a way that it’ll be away enough from the floating group?
It happens because that’s what a floating group is meant to do (by definition) - i.e. it floats above the page rather than being part of it…
So yes, just add a top margin to the first group on the page (or you can use a spacer element)…
