In bubble there’s 2 IPs each one with 2 names: empty and www
I already read the articles where it shows that empty is ‘@’ in some domain managers and I set it up like this in namecheap, but it’s still not working.
I tried removing one of the 2 IPs from name cheap right now (there’s only one IP in the screenshot above) and I’m waiting 24h again, but I think I’m missing something…
other solution by another user:
Then add “A” records, for the first 2 without any value in the “ Name: ” section simply input a “@” sign to represent root
Thank you for your answer.
I did exactly this setup 27 hours ago and it didn’t worked.
I opened a support asking for help directly to bubble since I’m apparently doing everything right.
