how can i make it so that user input has to match a code from the database to be able to continue to the next page.
so i want the user to enter a code (that will be given to them privately) in the input field, then i want to check if this code is valid/is in the database, and if so i want them to be able to get to the next page.
how do i do that, i have tried to go to workflow>when button is clicked>only when input´s value is do a search for>type: logincode> code = input´s value.
but it doesnt work. it requires more in the “only when” field.
i hope you understood my description.
