RG Data Issue. Not showing on frontend
Hi Folks
I am trying to call user data via an RG. On a list page I have a RG showing products and a RG showing Users
The products are showing up no problem, but the user data (using the same concept) does not and I just cannot see what I am doing wrong
The list data structure is:
On the user database (although not sure if it is needed) I have:
On the page I have the RG to show the users following this list set to:
exactly the same as I did for the products (which works perfectly).
I have checked the app data and confirm that the entries are correct, but the frontend just does not show any values.
What am I missing?
Hi there, @sebastianvangreunen… the issue could be related to privacy rules, specifically this rule. So, check out the link and see if it helps.
Best…
Mike
Issue resolved… privacy rules, indeed.
