I am having an issue between two popup groups on a reusable header element.
Workflow:
When I click on a sign up button in a popup situated in the reusable header element, it creates a workflow to open up the users dashboard page and show a different popup in the same reusable header element.
Sign up button - Sign User Up - Reset Input - Hide Element - Navigate To Page - Show Element
Problem:
However the last popup in the workflow does not show once the underlying page has loaded. It seems to be from testing that it shows while page is loading and once page has loaded it hides the popup.
You should see an issue on the issue checker. A change page action should always be the last action of a workflow. Let us know if you don’t see an issue, then it’s where the bug is.
I’ve done this by adding a field on the User called “firstTimeLogin” and set it as a “Yes/No.” I default it to Yes. When the user lands on that page, the popup shows when the page is loaded and firstTimeLogin is Yes.
