I have a workflow that is trigger on a button press to hide a button. This works fine, until the page is reloaded, then it is visible again. How can I hide it from the user permanently?
Hey @morgant6911 one way is to store the information on the User within a field. Iâm not sure what the best name for this field would be, but it could be something along the lines of:
âDisplay Buttonâ (Type: yes/no, List: No, Default Value: yes).
This fieldâs value would change from yes to no in the workflow youâre using to hide the button by âMaking Changes to a Thing --> Thing to Change: Current User --> Field to Change: Display Button = noâ.
Then in the conditional formatting of that button you could use:
When Current Userâs âDisplay Buttonâ is no --> this element is not visible.
And vice versa:
When Current Userâs âDisplay Buttonâ is yes --> this element is visible.
*Set the button to not be visible on page load and this should work
Thanks, that really helped. I had to do it in a slightly different way, but that did the job perfectly.
Awesome
No problem!
Me ajudou bastante. Thank you so much!
