how do i upgrade my entire app to the responsive engine? so that every time i make a new reusable element i dont have to upgrade them individually.
Hi @ksplinter007,
Unfortunately, I believe for apps made before new responsive became the primary responsive editor, they will default to the old responsive engine and you’ll need to manually upgrade. However, for apps made after new responsive, it’ll be standardized and use new responsive.
ok just wanted to make sure i wasnt missing anything. maybe they will add that ability down the line.
Yes, possibily!
